[Qgis-user] QGIS 1.5 - Ability to set WMS provider version?
David Fawcett david.fawcett at gmail.com
Fri Oct 1 08:56:23 PDT 2010
Jurgen,
Thanks for the quick reply.
I just figured it out.  It wasn't a problem with the WMS version.  The
layer was being added, but I wasn't seeing any imagery.  I think that
the problem was that when I was in the dialog where you choose the
layer from a connected WMS, I didn't select the radio button for JPEG.
This WMS only advertises/supports one imagetype, 'image/jpeg'.  Even
though there is only one Image Encoding option, the ratio button was
not selected by default.  I had added a WMS layer that was of type
image/png and the radio button was automatically selected by default.
So, user error.
Thanks again,
David.
On Fri, Oct 1, 2010 at 10:19 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi David,
> On Fri, 01. Oct 2010 at 10:11:40 -0500, David Fawcett wrote:
>> I have successfully used QGIS to consume WMS v 1.1 services in the
>> past, but I can't seem to get them to work with QGIS 1.5.0 (WinXP via
>> OSGEO4W built against 13923M).  The server is advertising only WMS
>> version 1.1 in the getCapabilities doc, but QGIS is using "OGC Web Map
>> Service version 1.3 data provider".
>> I can't find anywhere to manually set the correct WMS data provider.
> That's just a static string from QGIS' only WMS provider.  Which problems
> are you actually seeing?   And is that WMS public so other could try to
> reproduce?
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
