[Qgis-user] Re: QGIS 1.5 Update for ECW/SID support crashes
Francesco Parisi
fragger at altervista.org
Fri Oct 15 17:25:54 PDT 2010
i think i can correctly answer only to the 3rd question...
i'm using vmplayer to work with a virtual machine with the OS windows xp
sp3, with vmplayer it's also possible to mount ISO images, the guest OS
recognizes them as normal DVD-ROMs, so in my case i've prepared an ISO with
the all necessary ecws, then i've opened qgis (Guest OS) -> i have imported
the rasters -> i've saved the project (qgs file) -> i've copied the qgs
project on windows7 (with the vmware tools it's possible to do this with a
simple drag and drop) -> but qgs file has been wrote to locate the rasters
on the ISO, so i have opened it with the notepad (thanks to the open source
philosophy the qgs files are not encrypoted) and i have corrected manually
the location of the ecws (they were present in a directory of the HD).
At this point it's possible to work with the project without other
drawbacks. As i've said before it's a clumsy solution, but the other
alternatives that i've read in this forum didn't work for me.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-1-5-Update-for-ECW-SID-support-crashes-tp5442247p5640893.html
Sent from the qgis-user mailing list archive at Nabble.com.
