[Qgis-user] Re: QGIS 1.5 Update for ECW/SID support crashes
Francesco Parisi
fragger at altervista.org
Sun Oct 17 12:56:51 PDT 2010
Jürgen E. Fischer wrote:
> [1] http://trac.osgeo.org/gdal/wiki/ECW
to be true some minutes ago i've found that link and so i've googled for
this file: libecwj2-3.3-2006-09-06.zip that is an archive with the source
code of the ECW SDK 3.3 , that archive is in effect available on filetube
(1st result of the google search) so the linux/unix users can compile the
code without problems... but what about the windows users? this link here
http://trac.osgeo.org/gdal/wiki/ECW report the following instructions:
"Building GDAL with ECW support on Windows
TO BE DONE"
I'm wondering if the GCC (http://trac.osgeo.org/gdal/ticket/3162) is good
enough to compile that source code in binary, and if there is a tested
procedure to do it...
so i can try to use the right dlls... how much troubles to handle the ecw
format with qgis in w7... anyway... thanks for the information.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGIS-1-5-Update-for-ECW-SID-support-crashes-tp5442247p5645101.html
Sent from the qgis-user mailing list archive at Nabble.com.
