AW: AW: Re: Fwd: [Qgis-user] QGIS "Near"
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Wed Oct 27 22:48:35 PDT 2010
Hi Giuseppe
thanks for looking into this. Do you think it's worth filling out a bug report since the nearestNeighbor method does not the  keep the promise or is this the normal behaviour of a spatial index based method?
regards
Stefan
mit freundlichem Gruss
Stefan Ziegler
----- Originalnachricht -----
Von: "Giuseppe Sucameli" <sucameli at faunalia.it>
Gesendet: Mit, 27.10.2010 17:30
An: "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch>
Cc: "Jim Hammack" <hammack at gotslack.org> ; qgis-user <qgis-user at lists.osgeo.org>
Betreff: Re: AW: Re: Fwd: [Qgis-user] QGIS "Near"
Hi Stefan,
your workaround works fine in my case!
I looked at the QgsSpatialIndex code and I have bad news... It uses the bounding box
of the geometries!
This means that your workaround can work in a lot of cases but not in all cases, e.g. if
you have more than N geometries (10 considering your workaround), ones inside
each other.
Cheers.
On Tue, Oct 26, 2010 at 6:47 PM, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
Hi Giuseppe
I wrote a little workaround. Could you please update to 0.0.6 and check it with your test case? Thanks.
regards
Stefan
Stefan Ziegler
Gesendet: Mon, 25.10.2010 14:09
Hi all,
two days ago I wrote a similar plugin for a LD talk  in Pisa.
I was unaware of the QgsSpatialIndex class (seems there's no documentation
about it in the online QGis API  pages or maybe I missed it) so I wrote a simple
loop to find the closest feature.
Now I tried also the Nearest plugin and they are different behavior!
See the scheenshots [1] [2].
AFAICS, Nearest select a wrong polygon.
I see the plugin's code and I think it could a QgsSpatialIndex bug, but it could be
also the normal behaviour (I didn't found its documentation on the API pages
so I don't know).
I'm going to add my plugin (ClosestFeatureFinded) to the Faunalia repo so you
can try it and check the different behavior.
I hope this can help to find the bug (if any).
If you confirm it, I'll fill a bug report.
Cheers.
[1] http://img87.imageshack.us/img87/3232/nearest.jpg
[2] http://img64.imageshack.us/img64/2066/closest.jpg
On Fri, Oct 22, 2010 at 9:19 AM, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
there is some strange behaviour when using it with polygon features (at least I think it's a bit strange): sometimes when you click into a polygon I would expect that it selects the polygon I clicked into but it selects an adjacent polygon. This is probably due to the nearestNeighbor method of the spatial index. Since the two neighboring polygons share a common border the distance would be equal but the spatial index does not check if the coordindates of the mouse click lies within one of the two polygons.
regards
Stefan
Stefan Ziegler
Von: "Jim Hammack" <hammack at GotSlack.org>
Gesendet: Don, 21.10.2010 19:20
Cc: qgis-user <qgis-user at lists.osgeo.org>
    Stefan,
             I was looking for the same functionality as Zoran so have
        also been working with your "Nearest" plugin.  It is exactly
        what I need and seems to work well.
        Thanks!
        Jim
    On 10/20/2010 01:54 PM, Ziegler Stefan wrote:
      Hi Zoran
      I had some time left, took all
            my code snippets and also the one from Carson. Please try
            the plugin "Nearest" that should cover your example 1:
      http://www.catais.org/qgis/plugins.xml
      regards
      Stefan
        -----Ursprüngliche
            Nachricht-----
            Von: Zoran Jankovic [mailto:zoran.jankovic at zisis.hr]
            Gesendet am: Mittwoch, 20. Oktober 2010 19:21
            An: qgis-user
            Betreff: Re: Fwd: [Qgis-user] QGIS "Near"
          Hi Joe,
          On Wed, Oct 20, 2010 at 5:06 PM, Joe
            Larson <joelarso at gmail.com>
            wrote:
              Does the function 'snapWithContext'
              http://doc.qgis.org/head/classQgsVectorLayer.html#733b974dce13d587e05cf3d4fc24f208
              which "Snaps to segment or vertex within given tolerance."
              seem like
              what you're looking for? I came across it while trying to
              get Quantum
              Navigator working recently...seemed relative, but I'm no
              expert!
            This is similar to the mentioned solution with
              selecting by radius, or changing the tolerance of ID tool.
              Close, but no cigar. Since this is not very urgent, I've
              decided to continue pursuing that outlined solution Carson
              gave, and write a plugin i Python based on that. Since I
              actually never used Python before, it may take a while,
              but hey, I get to learn sth. new :-).
            I never got the word back from Carson, has he developed
              anything along these lines, but I have to presume he
              didn't...
            Anyone interested in joning me, or even earning some
              money, is still invited to jump on board. My GIS
              implementation project is well on the way, and it seems
              there'll even be some money involved :-).
            Zoran
              ~joe
              On Tue, Oct 19, 2010 at 9:55 AM, Andreas Neumann
              <a.neumann at carto.net>wrote:
                  > Hi Zoran,
                  > I believe the infrastructure of what you want is
                  already wihtin the
                  > selection and identify tools in QGIS. Isn't this
                  almost implemented in the
                  > current identify tool?
                  It sort of is, but not completely. Identify will ID
                  all the features within
                  certain radios (percentage of extent), but it will ID
                  _all_ of the features
                  within this radius. I only need the nearest, no matter
                  how far away... Let
                  us say it is, for simplicity, within current extent.
                  > The current identify tool selects "near" or
                  "close by" features within a
                  > certain tolerance. This tolerance can be set in
                  "Options" --> "Map tools"
                  > "search radius". I believe it currently only
                  effects the identify tool. Do
                  > you want the same tolerance also be used for the
                  click-selection tool?
                  Look above. This could be useful, but it is not the
                  functionality I'm
                  currently looking after.
                  > Are you also aware that in QGIS 1.6 there are new
                  selection tools?
                  > * by click
                  > * by rectangle
                  > * by polygon
                  > * by freehand
                  > * by radius
                  Yup, these are great, but they all select _multiple_
                  features within radius,
                  rectangle, etc.
                  > Maybe this also helps to address your needs?
                  > Of course you can combine it with previous
                  selections by pressing the ctrl
                  > key.
                  BR,
                  Zoran Jankovic
                  ZIS-Izrada softvera i savjetovanje / ZIS - Software
                  Development and
                  Consulting
                  http://www.zisis.hr
                  M: 00 385 98 682 902
                  T:  00 385 44 683 374
                  A. Senoe 4
                  44320 Kutina
                  Croatia
                  Qgis-user mailing list
                  Qgis-user at lists.osgeo.org
                  http://lists.osgeo.org/mailman/listinfo/qgis-user
Giuseppe Sucameli
Giuseppe Sucameli
