[Qgis-user] Save group layers in Quantum GIS 1.5?
Stefan Kiefer
st_kiefer at web.de
Wed Sep 8 03:42:59 PDT 2010
Hi Els,
as far as I know this is not possible. Actually it makes not much sense.
You can group layersm and it looks as if you have done this already. if
you want to keep your legend settings then you can save them in the
legend settings dialog. Actually if you give the legend fiel the same
name as the file of the layer it will be loaded automatically when
loading the file.
Hope this helps you a bit. Maybe somebody else has a better idea.
cheers
Stefan
Am Mittwoch, den 08.09.2010, 11:40 +0200 schrieb Els Dens:
> Is it possible in QGIS 1.5 to save a combination of vector and raster
> layers to a kind of 'layer file', in order to be able to load this
> combination of layers into a new project (saving also the previously
> defined symbology and labeling, …)?
> I give an example of a combination of vector and raster layers in the
> screenshot below. I would like to save this combination of layers to
> be able to use it in my later projects too.
> Thank you for the information!
> Els
> Aan dit bericht kunnen geen rechten worden ontleend. Alle berichten
> naar dit professioneel e-mailadres kunnen door de werkgever gelezen
> worden.
> Ondernemingsnummer: 0253.973.219
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100908/b2a9bfdf/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100908/b2a9bfdf/attachment.png>
