AW: AW: [Qgis-user] Python not loaded on startup
Möri Cedric
Cedric.Moeri at bd.so.ch
Wed Sep 8 06:18:01 PDT 2010
Borys,
are you refering to
https://trac.osgeo.org/qgis/ticket/2446
If I test for my sip version it's indeed #040a00.
On the other hand, I don't have a compile problem but a runtime problem.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Borys Jurgiel" <borysiasty at gmail.com>
Gesendet: Mit, 8.9.2010 11:51
An: qgis-user at lists.osgeo.org
Cc: "Möri Cedric" <Cedric.Moeri at bd.so.ch>
Betreff: Re: AW: [Qgis-user] Python not loaded on startup
Cedric,
Look into the archive, a similar problem was raised here a few months ago. AFAIR it was because cmake was comparing the sip versions as strings, so your "4.10.1" < "4.7.1". It was fixed on the compiling stage, but seems you get it a step farther.
Dnia środa 08 września 2010 o 11:39:24 Möri Cedric napisał(a):
> Okay, thanks.
> But where or how to get/update it? Which package is the SIP API in?
> If searching in synaptic for 'sip', I find the following packages
> installed: sip4, python-sip, python-sip-dev,
> python-sip-dbg,python-sip4-dev,python-sip4-dbg All of them are version
> 4.10.1-0ubuntu1
> regards
> Cédric
> Cédric Möri
> GIS-Informatiker
> Kanton Solothurn
> Rötistrasse 4
> 4501 Solothurn
> Von: "Noli Sicad" <nsicad at gmail.com>
> Gesendet: Mit, 8.9.2010 11:15
> An: "Möri Cedric" <Cedric.Moeri at bd.so.ch>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Betreff: Re: [Qgis-user] Python not loaded on startup
> "SIP module implements API v7.0 but the qgis.core module requires API v7.1"
> You have get SIP module version 7.1 as PyGIS qgis.core module requires API
> v7.1
> Noli
> Qgis-user mailing list
