[Qgis-user] RE: Shapefile structure viewer and editor plugin
Andrea Peri aperi2007 at gmail.com
Sat Sep 11 09:19:10 PDT 2010
It a core component.
You find it in the "attribute" window
2010/9/11 Noli Sicad <nsicad at gmail.com>
> Hi Andrea.
> Which plugin is the "calculator"?
> Or is qgis core component?
> Regards,
> Noli
> On 9/11/10, Andrea Peri 2007 <aperi2007 at gmail.com> wrote:
> >   > am searching for a plugin that calculates the area and perimeter of
> >  >polygons of shapefiles and other vector layers e.g. spatialite
> >  >I think there is none at the moment, if I am not mistaken.
> >  >However, you can get the area and perimeter of the layer using fTools.
> >  >Vector-> Geometry tools -> Export / Add Geometry Columns
> > Hi noly,
> > you can even use the "area" button in the calculator.
> > You add a new columns and fill it with the button "area" in the
> calculator.
> > Unfortunately is missing the "perimeter" button.
> > But perhaps it could be a simple add ?
> > Regards,
> > Andrea.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100911/ef857554/attachment.html>
