[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
sergio sevillano sergiosevillano.mail at gmail.com
Tue Sep 14 07:55:05 PDT 2010
El 14/09/2010, a las 14:52, William Kyngesburye escribió:
> Are you using the standalone Qgis?
i have installed frameworks and qgis manually from
http://www.kyngchaos.com/software/qgis
but not sure if its standalone or not
is there a way i can check?
> What other GDAL tools have you used that work, besides gdal_contour?  gdal_merge itself is a python program, while gdal_contour is a binary.  It seems that an external python script is having problems finding python
other .py won´t work either
> On Sep 14, 2010, at 5:59 AM, sergio sevillano wrote:
>> hi
>> i get an
>> "env: python: No such file or directory"
>> error when i try to use GDAL Tools plugin to merge some .hgt images
>> seems to me as a path thing
>> but other gdal plugins work fine
>> as gdal_contours
>> any hint or place to look further?
>> thanks
>> sergio
>> intel mac 3.33GHz core 2 duo - 8Mb ram
>> OSX 10.6.4
>> Qgis 1.5.0 "Tethys"
>> GDAL Tools 1.2.0 (using GDAL v. 1.7.2)
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
