[Qgis-user] Split line into multiple lines at nodes
Micha Silver micha at arava.co.il
Thu Sep 16 05:13:59 PDT 2010
On 16/09/2010 13:13, Ghislain Picard wrote:
> No it's different. The tools "single parts to multipart" converts
> feature made of several disjoint parts into several features.
Ah, I misunderstood. You want to actually split the line up at every vertex?
If you're using GRASS, then I can suggest a two step procedure:
You get all the vertex coordinates into a text file using v.to.points -v
Then loop thru the text file and use each pair of coords as input to
v.edit tool=break coords=x,y
A bit fiddly but it should give you a vector with each line segment as a
separate feature.
> On 09/16/2010 08:53 AM, Micha Silver wrote:
>> On 15/09/2010 21:50, Ghislain Picard wrote:
>>> Hi,
>>> I have one trajectory made of several segments in a shapefile and
>>> would like to convert this into the individual segments
>>> An example is here:
>>> http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Split_Line_At_Vertices_%28Data_Management%29
>>> How to do this with QGis ?
>> I think what you want is:
>> Vector->Geometry Tools->Single parts to multipart
>>> Cheers,
>>> Ghislain
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
