[Qgis-user] Toggle editing question
Erica Donnelly-Swift
donneler at tcd.ie
Mon Sep 20 06:05:23 PDT 2010
Hi Benoit,
Thank you for your response....
> you could use Vectors -> Geometry Tools -> Multipart
> to singleparts
yes this solves the problem.
Many thanks
Erica
On 20 Sep 2010, at 12:53, Benoit de Cabissole wrote:
> Hi Erica,
> Looks like you have a multipart-multilines vector file.
> On your PrimaryRd.shp you could use Vectors -> Geometry Tools ->
> Multipart
> to singleparts
> to create individual lines for each of your road sections.
> And then used the resulting shapefile to onlt select the roads you
> want.
> Hope this helps,
> Benoit
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of Erica
>> Donnelly-Swift
>> Sent: Monday, 20 September 2010 12:35
>> To: qgis-user at lists.osgeo.org
>> Subject: [Qgis-user] Toggle editing question
>> Hi all,
>> I'm working on a road network vector file, however I have encountered
>> a small issue, and I would be very grateful if you could please offer
>> some advice, thanks
>> Q: How can I get QGIS to delete specific sections of road? (And not
>> delete the whole primary road network)
>> I worked with this road vector map a few months ago and managed to
>> select a specific route using toggle editing....I'm unsure why there
>> seems to be a problem this time.....
>> I have outlined the steps below
>> (I'm working on MAC OSX 10.5.8, QGIS version 1.4.0 Enceladus)
>> 1) I have uploaded the roads.shp through QGIS (roads.shp is a file
>> for a road network)
>> 2) I went into the attributes table and selected the Primary roads
>> Attribute table contents:
>> ID RoadType Length
>> 0 Motorway XXXX
>> 1 Primary XXXX
>> 2 Secondary XXXX
>> 3 Regional XXXX
>> 3) I saved the selected primary roads as a PrimaryRd.shp file
>> 4) I loaded this PrimaryRd.shp file into QGIS
>> 5) I selected toggle editing mode, but when I select features - all
>> roads are highlighted and when I delete.... it deletes all the roads
>> I think it may possibly be related to the attributes table, but I'm
>> unsure how to expand this table
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
