[Qgis-user] Re: Projection of Shapefile export
Ken Norris
ken.norris at wideband.net.au
Wed Sep 22 21:47:14 PDT 2010
As Micha suggested, the National AGD66 distortion grid at
http://www.icsm.gov.au/icsm/gda/gdatm/national66.zip
and AGD84 distortion grid at
http://www.icsm.gov.au/icsm/gda/gdatm/national84.zip
seem to be the way forward.
When unzipped, put into the proj directory (for me usr/share/proj) and
coupled via the +nadgrids= parameter in a Custom CRS, it seems to yield the
correct transform when tested.
+proj=utm +zone=55 +south +ellps=aust_SA +nadgrids=AGD66.gsb +units=m
+no_defs
(I renamed the unzipped distortion file 'A66 National (13.09.01).gsb' file
to 'AGD66.gsb' for convenience)
But I can't make the parameters stick in the CRS of a vector file using the
override facility. Any ideas?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Projection-of-Shapefile-export-tp5536736p5561744.html
Sent from the qgis-user mailing list archive at Nabble.com.
