[Qgis-user] diffrent colour on polygones
Pierre Chevalier Géologue
pierrechevaliergeol at free.fr
Sat Sep 25 02:38:53 PDT 2010
pcreso at pcreso.com claviota:
> Right click on the layer name in the left window.
> Choose symbology
> There are various options to use, including having colours assigned by an attribute, for a different colour for every polygon, use your unique id field to assign colours to.
In mapinfo terms, this is the equivalent of doing a "thematic analysis"
("analyse thématique" in French; I'm not sure about the exact English
mapinfo terms).
>> I am a newbie on Q-gis, used Map Info Pro before
There is definitely a learning curve between these tools. I also used
mapinfo a lot *before*. No I use qgis for almost all GIS tasks. I DON'T
regret mapinfo! Except a few things: the mapbasic window that writes
whatever action you do with the GUI was really handy. Also the
ultraflexibility of mapinfo in handling dozens of different CRS: this
sometimes lacks in qgis (see other threads going on about australian CRS
in this list).
But the ability to open .mif-mid's, .shp's, .tab's directly in qgis
without conversion is just excellent! And countless other things.
Now, one warning: if you have worked in the most "dirty" way in mapinfo
(this software sometimes doesn't discourage you to do so...), i.e.
assigning directly colours, linestyles to objects, or mixing lines,
polygons, texts in one layer, you may get a bit disappointed: you cannot
do such things in qgis. You have to work in a clean way. Like Brent just
said, graphical appearance of vector objects depends on data attributes.
And one layer per object type, it is much cleaner.
>> I hope my question isn´t to stupid
The stupid questions are the ones that are never asked.
>> Really need to ger a grip of this
Courage: you will not regret!
A+
Pierre
____________________________________________________________________________
Pierre Chevalier Géologue EI
Mesté Duran
32100 Condom
Tél+fax : 09 75 27 45 62
05 62 28 06 83
06 37 80 33 64
Émail : pierrechevaliergeolCHEZfree.fr
icq# : 10432285
skype : pierre.chevalier1967
http://pierremariechevalier.free.fr/pierre_chevalier_geologue
