[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
William Kyngesburye
woklist at kyngchaos.com
Tue Sep 28 09:52:25 PDT 2010
On Sep 27, 2010, at 3:35 AM, sergio sevillano wrote:
>> El 14/09/2010, a las 17:13, William Kyngesburye escribió:
>>> I get this also. I'm using the standard Qgis.
>>> My guess is that external python scripts aren't getting a shell environment so they can't find python, even though Qgis extensions run thru python. Those GDAL python scripts all have the standard shebang:
>>> #!/usr/bin/env python
>>> Someone with a better understanding of this needs to comment so I can try to figure out why the Mac build is not working (while from lack of reported problems it seems other systems work).
> i have tried to start all over
> as i had my system very messy (flink, darwin, several pythons...)
> so i formated my hdd and start with a clean OSX
> is there any older version of Qgis that works
> in an intel mac with SnowLeopard (OSX10.6.x)
> that has a working GDAL plugin ?
The GDAL plugin is new in Qgis 1.5, so no previous versions "worked". I doubt any of my dev builds of 1.5 worked.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
