[Qgis-user] Projection of Shapefile export
Micha Silver
micha at arava.co.il
Thu Sep 16 02:55:59 EDT 2010
On 16/09/2010 03:19, Brett Adams wrote:
> Hi folks,
> When I export a layer as a shapfile the projection is always WGS84,
> even though I specify AGD84 on export.
> Am I doing something wrong or is this a bug?
Are you sure the original shapefile has correct CRS data? That is, does
it have a *.prj ?
Also, I'm not 100% sure that exporting to a new CRS was available in
1.4. You might go ahead and upgrade to 1.5 where the feature does work.
> Running Version 1.4.0
> Thanks
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
