[Qgis-user] Announcing "Time Manager" Plugin v 0.1
Volker Fröhlich
volker27 at gmx.at
Thu Sep 30 15:44:04 EDT 2010
Yes, that's related to Python's datetime module. But the limit only exists for
real dates. You may not need that precision for dates beyond those borders.
We're likely to make the plug-in accept numeric values. That should do for
cases, where really long periods of time are observed. It will also enable the
use of data, where time is not necessarily on a cardinal scale, e. g.
chronologic order of samples.
The limit of the time frame size isn't much of a deal either: You probably
won't need split seconds precision for month-long intervals.
Volker
Am Donnerstag 30 September 2010, 21:15:42 schrieb MORREALE Jean Roc:
> Sorry, I was speaking about the 1-9999 time range.
> Le 30/09/2010 21:08, Volker Fröhlich a écrit :
> > What kind of limit do you mean? The limit in the range of time, or the
> > limit in time frame size, as mentioned in the Wiki? Or do you mean the
> > limit in formats?
> > Regards
> > Volker
> > Am Donnerstag 30 September 2010, 20:45:50 schrieb MORREALE Jean Roc:
> >> Great tool Anita !
> >> I'll give it a try as soon as possible, is the time limit a choice or
> >> technical limitation ?
> >> Regards,
> >> MORREALE Jean Roc
> >> Le 30/09/2010 20:39, Anita Graser a écrit :
> >>> Hi,
> >>> I'm happy to present to you the first version of "Time Manager" plugin
> >>> for QGIS, developed by Volker Fröhlich and myself.
> >>> The aim of Time Manager plugin is to provide comfortable browsing
> >>> through temporal geodata. A dock widget provides a time slider and a
> >>> configuration dialog for management of your layers.
> >>> Get an impression at: http://www.geofrogger.net/trac/
> >>> The Trac also lists our plans for future development, including
> >>> features like exporting animations and support of different time stamp
> >>> formats.
> >>> Please be aware that Time Manager requires current trunk to function
> >>> correctly.
> >>> Looking forward to receiving your feedback!
> >>> Anita& Volker
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
