[Qgis-user] postgis and custom CRS
Duarte Carreira
DCarreira at edia.pt
Fri Apr 8 01:41:44 PDT 2011
But shouldn’t QGIS identify the CRS correctly? Or at least say it is unknown? Stating the wrong CRS will misguide users.
Duarte
De: pcreso at pcreso.com [mailto:pcreso at pcreso.com]
Enviada: quinta-feira, 7 de Abril de 2011 20:34
Para: Duarte Carreira
Cc: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] postgis and custom CRS
You'll need to define the coordinate system in QGIS as well as PostGIS, & probably tel QGIS which projection to use fro the project & the layer.
Brent Wood
--- On Fri, 4/8/11, Duarte Carreira <DCarreira at edia.pt> wrote:
Subject: [Qgis-user] postgis and custom CRS
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Date: Friday, April 8, 2011, 5:15 AM
Hi.
I’m seeing this behavior and would like to confirm it.
When I add a PG layer that has a custom CRS, QGIS says it is WGS84 (in the metadata tab in properties).
In PG I have the custom CRS defined like this:
Srid: 9102160
Auth_name: ESRI
Auth_srid: 102160
Srtext: "PROJCS["Datum_73_Hayford_Gauss_IGeoE",GEOGCS["GCS_Datum_73",DATUM["Datum_73",SPHEROID["International_1924",6378388,297]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",200180.598],PARAMETER["False_Northing",299913.01],PARAMETER["Central_Meridian",-8.131906111111112],PARAMETER["Scale_Factor",1],PARAMETER["Latitude_Of_Origin",39.66666666666666],UNIT["Meter",1],AUTHORITY["EPSG","102160"]]"
Proj4text: "+proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111112 +k=1 +x_0=200180.598 +y_0=299913.01 +ellps=intl +units=m +towgs84=-288.885,-91.744,126.244,-1.691,0.410,-0.211,-4.598 +no_defs"
Can someone confirm?
Thanks,
Duarte
-----Inline Attachment Follows-----
Qgis-user mailing list
Qgis-user at lists.osgeo.org</mc/compose?to=Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110408/f9c905d6/attachment.html>
