[Qgis-user] No geometry for sql server
Yves Jacolin
yjacolin at free.fr
Wed Apr 13 01:07:20 PDT 2011
Christophe,
Why do you say the issue come from the python code? Your example shows nothing
What is the result of your last command?
Y.
Le mercredi 13 avril 2011 09:49:04, Christophe B a écrit :
> Hello Yves,
> I tried to convert my table to a shapfile with ogr2ogr (GDAL 1.8.0,
> released 2011/01/02) and it works : my shapfile has geometry and attribute
> data. It is therefore a problem whis python code !
> >>> conn_string ="MSSQL:server=.\SQLEXPRESS;
> database=ObservatoireCommerce;tables=dbo.T_CommuneGeographie;trusted_connec
> tion=yes"
> >>> qgis.utils.iface.addVectorLayer(conn_string,'test','ogr')
> 2011/4/12 Yves Jacolin <yjacolin at free.fr>
> > Christophe,
> > could you test ogr directly to connect to your SQL Server? For example
> > convert
> > sql server layer into shapefile. You will know if this is an ogr or QGIS
> > issue.
> > Y.
> > Le mardi 12 avril 2011 12:39:21, Nathan Woodrow a écrit :
> > > This seems to be a bug, I have noticed it is happens mainly on Windows
> > XP
> > > but Windows 7 also has this bug. I'm not sure where the problem is, I
> > > suspect QGIS as OGR via command line returns the correct objects.
> > > - Nathan
> > > On Tue, Apr 12, 2011 at 8:16 PM, Christophe B <ampouillle at gmail.com>
> > wrote:
> > > > Hello List,
> > > > I now test the ability to connect to SQL Server data whis GDAL 1.8 of
> > > > QGIS 1.7.
> > > > The connection is correct but I have no geometry in return, and the
> > right
> > > > attribute data (error).
> > > > Is a problem in GDAL / OGR? or QGIS 1.7?
> > > > Should we open a new ticket ?
> > > > Thank you in advance
> > > > Christophe Baume
> > > > _______________________________________________
> > > > Qgis-user mailing list
> > > > Qgis-user at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Yves Jacolin
> > http://yjacolin.gloobe.org
Yves Jacolin
