[Qgis-user] raster stats
Radim Blazek
radim.blazek at gmail.com
Thu Apr 14 04:24:54 PDT 2011
New ticket http://trac.osgeo.org/qgis/ticket/3735
Radim
On Mon, Mar 21, 2011 at 4:37 PM, John Callahan <john.callahan at udel.edu> wrote:
> I'm not sure if this behavior is expected or I am missing something.
> I have a 1 band raster dataset (an elevation DEM) in TIF format. It has
> statistics computed from "gdalinfo -stats mydata.tif" However, when I open
> it in QGIS (both 1.6 and 1.7 trunk), and look at the Metadata tab in Layer
> properties, there are two sections that contain band stats information. The
> first section is labeled "Band 1" and lists the same stats as found using
> gdalinfo. The second section is labeled "Band" and says "No stats collected
> yet" for band 1. QGIS has to create the stats when I apply a color map or
> stretch. For large rasters, this takes a while, and must be done each time
> it's used in QGIS.
> Has anyone experienced this behavior? Is this expected? Is there a way to
> let gdal compute all the stats that QGIS needs? Thanks.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> Qgis-user mailing list
