[Qgis-user] styling a KML/KMZ file using QGIS?
Jürgen E. Fischer jef at norbit.de
Thu Apr 21 15:24:36 PDT 2011
Hi John,
On Thu, 21. Apr 2011 at 15:03:27 -0700, John C. Tull wrote:
> Unfortunately, this plugin causes a segmentation fault for me, so it is still unusable. I've pasted a gdb log running a debug build. My test was to open the application, then try to load a simple test shapefile (although this crash appears to occur on loading any vector data source). I don't know if this will help determine what the cause is or not. Disabling the plugin results in normal behavior for QGIS.
> Debug: /Users/jctull/sources/qgis/trunk/src/app/legend/qgslegendlayer.cpp: 92: (QgsLegendLayer) Connecting signals for updating icons, layer temp
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000000
> 0x000000011d2cb88b in qgis2google::setDefaultSettings (this=0x10583c990, layer=0x121265170) at /Users/jctull/sources/qgis/trunk/src/plugins/qgis2google2/qgis2google.cpp:181
> 181	    QList<QgsSymbol *> symbols = vlayer->renderer()->symbols();
Looks like qgis2google2 doesn't know about symbology-ng and assumes that you're
not using it, but you probably aren't.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
