[Qgis-user] Connect to PostGIS Without Superuser Privileges
Elijah Meeks emeeks at stanford.edu
Sat Aug 6 22:39:59 PDT 2011
I resolved this problem.  It seems I was trying to GRANT permissions with a superuser in phpPgAdmin.  Logging in with postgres at the terminal allowed me to GRANT access as I wanted to the tables.
-Elijah
Elijah Meeks
http://dhs.stanford.edu
Digital Humanities Specialist
Academic Computing Services
Stanford University
(650)387-6170
----- Original Message -----
To: "Brent Wood" <pcreso at pcreso.com>
Cc: qgis-user at lists.osgeo.org
Sent: Saturday, August 6, 2011 8:33:27 PM
Subject: Re: [Qgis-user] Connect to PostGIS Without Superuser Privileges
Hi Brent,
I'm connecting via the Add Vector Layers dialogue.  It works fine if the role is a superuser--and the hb_conf is set up correctly.
Thanks,
Elijah
Elijah Meeks
Stanford University
(650)387-6170
To: "Elijah Meeks" <emeeks at stanford.edu>
Sent: Saturday, August 6, 2011 8:10:44 PM
Check the Postgres server pg_hba.conf to make sure the specified user/IP address has access to the required db.
Also, how are you trying to connect? The normal QGIS connection dialogue does not use the GDAL/OGR string you are defining.
It prompts for an arbitrary name, a service I leave blank, the port (which defaults to 5432) the host & the database. Optional user & password. Quite a different syntaxt to yours.
Cheers,
Brent Wood
To: qgis-user at lists.osgeo.org
Sent: Sunday, August 7, 2011 2:48 PM
Subject: [Qgis-user] Connect to PostGIS Without Superuser Privileges
QGIS comes back with the following error if I try to connect to PostGIS:
PG:dbname='databasename' host='hostname' port='5432' user='username' password='password' is not a valid or recognized data source
(Databasename, hostname, username and password are all correct, I just changed them to generic values for this post)
The connection works fine when the user/role I connect with is a superuser, but errors out above when I remove superuser status. I've GRANTed ALL access to the db and the tables for the role, but no change. I noticed a three year old bug report/feature request similar to this, so I'm assuming I haven't got the right permissions set up. Any suggestions?
Thanks,
Elijah
Elijah Meeks
Stanford University
(650)387-6170
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
