[Qgis-user] to install qgis-plugin-grass in ubuntu always unsuccessful
Saber Razmjooei razmjooeis at faunalia.co.uk
Tue Aug 9 10:43:55 PDT 2011
try to run
sudo apt-get update
sudo apt-get install -f
from terminal.
Then try to run
sudo apt-get install qgis-plugin-grass
If it complains about conflicting version of grass, you need to create a
dummy grass package and install it.
Let me know if this works, otherwise I can explain how to create dummy
packages.
By the way, could you send me the output of this command
lsb_release -a
Cheers
Saber
> Dear All,
> Please help. I tried to install qgis-plugin-grass in ubuntu always
> unsuccessful. error message is "Could not apply changes! Fix broken
> packages first ". I have to do" fix broken packages "but have not
> succeeded. I'm using is Ubuntu 3.0.8. Anyone can help me, I say thank
> you.
> best,
> Zehari
> Qgis-user mailing list
