[Qgis-user] Find by Attributes plugin
Nomeneta Saili nome.saili at gmail.com
Tue Aug 16 21:59:47 PDT 2011
Hi people,
I installed this tool which allows me to quickly select our meters by
transformer and it was working before. Now i cant' select the
attribute (tansformer) from the attribute drop down menu. Does anyone
know what i need to do first?.
My meter table is open straight from my PostGIS database.
Thanks,
Nome
On Wed, Aug 17, 2011 at 5:00 AM,  <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>        qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: World File for map compositions (Markus Weidenbach)
>   2. DEM terrain models problem (Carlos Cerd?n)
>   3. Re: DEM terrain models problem (Paolo Cavallini)
>   4. Re: DEM terrain models problem (Marco Hugentobler)
> Message: 1
> Date: Mon, 15 Aug 2011 21:17:54 +0200
> From: Markus Weidenbach <landconsult at freenet.de>
> Subject: Re: [Qgis-user] World File for map compositions
> To: pcreso at pcreso.com
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <4E4970E2.5020106 at freenet.de>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Brent,
> thanks for your advice. I will try both, (a) manipulating and using the
> world file of the image I am saving outside the map composer and (b) the
> geo-referencing of the maps with the geo-ref. tools in QGIS.
> Since I am producing a series of 4-6 different thematic maps on each
> area of interest, I was hoping to find a more efficient way to
> geo-reference the maps, but on the other hand, because the maps series
> is always using the identical map template, a commonly used world file
> might be a feasible way to solve the problem .....
> I´ll find it out.
> Regards,
> Markus
> Dr. Markus Weidenbach
> *landConsult.de*
> Geographical Information Management
> and Environmental Planning
> D-77773 Schenkenzell
> Germany
> e.mail see: http://landConsult.de
> Am 13.08.2011 23:54, schrieb pcreso at pcreso.com:
>> Hi Markus,
>> If you choose "File -> Save as Image", then save as a PNG, for
>> example, the on screen image is saved, along with the world file
>> allowing it to be reused.
>> Note that the file suffix pngw will be used, not wld or pgw for the
>> world file.
>> However, I'm not aware of this being directly supported from the map
>> composer, but there are a couple of ways of doing this that might work
>> for you.
>> You could use the georeferencing tool to generate a world file from a
>> saved map composer image, but this can be a bit fiddly, although a
>> useful exercise for students in its own right..
>> You could also use an image processing tool to convert a composer
>> image to the same pixel geometry as a saved map window, in which case
>> the world file would also apply to it, or perhaps double the x & y
>> pixel counts (for better resolution) and halve the pixel offset values
>> in the world file. For this to work you'd need to have all the map
>> composer elements overlaying the actual map (if this is possible),
>> rather than outside the map, and therefore extending the apparent
>> image extent.
>> Cheers
>> Brent Wood
>> --- On *Sun, 8/14/11, Markus Weidenbach /<landconsult at freenet.de>/* wrote:
>>     Subject: [Qgis-user] World File for map compositions
>>     To: qgis-user at lists.osgeo.org
>>     Date: Sunday, August 14, 2011, 6:57 AM
>>     Dear list,
>>     is there a way to save a world file together with an image of a
>>     completely designed map in the map composer?
>>     The idea is to provide less experienced GIS users with a
>>     geo-referenced raster image (or pdf) of a complex map composition
>>     including an explaining legend, scale bar, north arrow and
>>     pre-defined layers in a specific order and layout. Such an image
>>     could easily be used by GIS beginners to visualize complex
>>     thematic issues and even add further layers or do some area/length
>>     measurements.
>>     Any hints and ideas how this could be managed are welcome.
>>     Regards,
>>     Markus
>>     *landConsult.de*
>>     Germany
>>     -----Inline Attachment Follows-----
>>     _______________________________________________
>>     Qgis-user at lists.osgeo.org </mc/compose?to=Qgis-user at lists.osgeo.org>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110815/e546513c/attachment-0001.html
> Message: 2
> Date: Mon, 15 Aug 2011 20:47:00 -0500
> From: Carlos Cerd?n <sig.upagu at gmail.com>
> Subject: [Qgis-user] DEM terrain models problem
> Message-ID: <4E49CC14.9030400 at gmail.com>
> Dear QGIS list members:
> I've got some ASTER_GDEM data
> (http://www.gdem.aster.ersdac.or.jp/search.jsp) and I was testing the
> /DEM terrain models/ GDAL tool with my DEM.
> The shaded relief map that I got is ok, but slope map is wrong: this one
> has 0 (zero) and over 89 degrees only, (there are not 1, 2, 3....88) .
> I've tried all options but I got always a 0 and 89 (and decimal) degress
> map.
> I've tried with the r.slope module (GRASS pluggin)  and it does a good
> job: I get a full-slope map.
> My distro: QGIS 1.7 on Ubuntu 11.04. A month ago I fixed it for the TIFF
> images problem reported here:
> http://osgeo-org.1803224.n2.nabble.com/gdal-1-8-0-no-tiff-support-anymore-in-Ubuntu-11-04-Natty-tc6365327.html
> It is relationed with this slopes problem?
> As I said, the GRASS pluggin did the right work, but I'd liked GDAL tool
> does too. Perhaps I did something wrong or Is something wrong with this
> tool?
> Thank you in advance for sugestions
> Regards from Cajamarca - Perú
> Carlos Cerdán
> URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20110815/0100bc61/attachment-0001.html
> Message: 3
> Date: Tue, 16 Aug 2011 09:11:51 +0200
> From: Paolo Cavallini <cavallini at faunalia.it>
> Subject: Re: [Qgis-user] DEM terrain models problem
> Message-ID: <4E4A1837.2090704 at faunalia.it>
> Content-Type: text/plain; charset=ISO-8859-1
> Il 16/08/2011 03:47, Carlos Cerdán ha scritto:
>> The shaded relief map that I got is ok, but slope map is wrong: this one has 0 (zero)
>> and over 89 degrees only, (there are not 1, 2, 3....88) . I've tried all options but
>> I got always a 0 and 89 (and decimal) degress map.
> Have you tried the palin GDAL command? Does it have different results?
> Please open a ticket with as many details as possible, better if with sample data and
> results.
> Thanks.
> Paolo Cavallini: http://www.faunalia.it/pc
> Message: 4
> Date: Tue, 16 Aug 2011 09:33:54 +0200
> From: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> Message-ID: <201108160933.54926.marco.hugentobler at sourcepole.ch>
> Content-Type: Text/Plain;  charset="utf-8"
> Hi Carlos
> Is it possible your map units are in degrees (and your elevation units are in
> meters)? If so, you could set the option '-s 111120' (see
> http://www.gdal.org/gdaldem.html)
> Regards,
> Marco
> Am Dienstag, 16. August 2011, 03.47:00 schrieb Carlos Cerdán:
>> map.
>> n-Ubuntu-11-04-Natty-tc6365327.html It is relationed with this slopes
>> problem?
>> tool?
>> Carlos Cerdán
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> End of Qgis-user Digest, Vol 66, Issue 24
