[Qgis-user] Problems loading postgis layers
Andreas Forø Tollefsen
andreasft at gmail.com
Wed Aug 17 04:54:58 PDT 2011
Hi all.
I recently upgraded my QGIS to 1.7. Previously using QGIS 1.6.
Now i cant load postgis layers from the same server as i used previously.
The problem occurs when i select a layer in the postgis connection and try
to add this.
For instance when trying to add the cshapes dataset i get this error:
Unable to access the "public"."cshapes" relation.
The error message from the database was:
ERROR: Unknown geometry type: 65536 - Unknown
SQL: select * from "public"."cshapes" limit 1
Then i get a 'Invalid Layer' box which tells me that the cshapes layer is
invalid and cannot be added to QGIS.
This happens with all of the 400 tables i have stored on my PostGIS server.
Any ideas why this happens?
Thanks in advance.
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110817/63ce8513/attachment.html>
