[Qgis-user] Problems loading postgis layers
Andreas Neumann a.neumann at carto.net
Wed Aug 17 06:13:19 PDT 2011
 If you migrate from Postgis 1.5.x to Postgis 2.0.x you have to do a
 hard upgrade. You have to dump the database before the upgrade and read
 it in again after the upgrade.
 See
 http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#hard_upgrade
 As this is a Postgis related problem - please ask at the Postgis
 mailinglist.
 Andreas
 PS: it is a good idea to dump your database every day for backup
 purposes. I use a cronjob for that. It is absolutely necessary to dump
 the database before you do a Postgis or library upgrade. Otherwise your
 data is really at risk.
 On Wed, 17 Aug 2011 14:55:35 +0200, Andreas Forø Tollefsen wrote:
> Thats it i guess. On the server i created a new database based on the
> new postgis 2.0 trunk. The previous was an earlier trunk. At the same
> time i upgraded some of the libraries i think.
> Any idea on how to solve this except recreating the whole database?
> I am not sure how a recovery from backup will work now.
> The new database based on the latest postgis 2.0 trunk works without
> problems. Strange...
>  Thanks,
> Andreas
> 2011/8/17 Andreas Neumann
>> yes, seems like a more serious problem in Postgis.
>> Perhaps consult the Postgis mailinglist about it?
>> Did you recently run an upgrade on this database? Or other changes
>> of the underlying libraries, such as geos?
>> Andreas
>> On Wed, 17 Aug 2011 14:35:49 +0200, Andreas Forø Tollefsen wrote:
>>> Hi Andreas,
>>> I tried using pgAdmin to access a file.
>>> i.e.
>>> query: SELECT * FROM priogrid;
>>> ERROR:  Unknown geometry type: 0 - Unknown
>>> ********** Error **********
>>> SQL state: XX000
>>> I also tried to do this on the computer running the server. From
>>> terminal.
>>> psql priogrid
>>> and then
>>> Same error: ERROR: Unknown geometry type: 0 - Unknown.
>>> Maybe i have corrupted my whole database. I can access all the
>>> table
>>> columns except for the geometrical ones.
>>> Any ideas?
>>>> Hi,
>>>> Did you double check that the permissions are ok and that all
>>>> the
>>>> Postgis connection parameters are ok (or perhaps different from
>>>> version 1.6)?
>>>> Can you access the Postgis tables with pgAdmin3 from the same
>>>> machine using the same credentials?
>>>> It could be a number of issues - permissions or wrong
>>>> connection
>>>> settings are quite likely.
>>>> Andreas
>>>> On Wed, 17 Aug 2011 13:54:58 +0200, Andreas Forø Tollefsen
>>>> wrote:
>>>>> Hi all.
>>>>> I recently upgraded my QGIS to 1.7. Previously using QGIS
>>>>> 1.6.
>>>>> Now i cant load postgis layers from the same server as i used
>>>>> previously.
>>>>> The problem occurs when i select a layer in the postgis
>>>>> connection and
>>>>> try to add this.
>>>>> For instance when trying to add the cshapes dataset i get
>>>>> this
>>>>> error:
>>>>> Unable to access the "public"."cshapes" relation.
>>>>> The error message from the database was:
>>>>> ERROR: Unknown geometry type: 65536 - Unknown
>>>>> SQL: select * from "public"."cshapes" limit 1
>>>>> Then i get a 'Invalid Layer' box which tells me that the
>>>>> cshapes
>>>>> layer
>>>>> is invalid and cannot be added to QGIS.
>>>>>  This happens with all of the 400 tables i have stored on my
>>>>> PostGIS
>>>>> server.
>>>>>  Any ideas why this happens?
>>>>>  Thanks in advance.
>>>>> Andreas
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>> Links:
>>> [1] mailto:a.neumann at carto.net [1]
>> Andreas Neumann
>> Switzerland
> Links:
> [2] mailto:a.neumann at carto.net
 Andreas Neumann
 Switzerland
