[Qgis-user] Re: Announcement QGIS WPS Client major upgrade
Horst Düster horst.duester at kappasys.ch
Mon Aug 22 03:50:24 PDT 2011
Hi Luca
I tested your data and it seems to be an encoding problem. When I save
the point shape-layer as a new layer with encoding latin1 it works fine
for me.
Ill have a look at the plugin code.
Regards
Horst
Am 22.08.2011 11:41, schrieb Luca Casagrande:
> Horst Düster wrote:
>> Today I published a major upgrade of the QGIS WPS Plugin. Now the client
>> is running as a dockwidget. Processes now are running as asynchronous
>> processes. As the result the GUI is not freezed and you can go on with
>> your work during the process is running. Additionally you have the
>> option to kill a running process.
>> For testing purpose I set up some WPS based on PyWPS. Please give it a
>> try. At the moment the server has some limitations:
>> - upload is limited to 3Mb
>> - max 3 simultaniously running processes.
>> The process URL:  http://www.kappasys.ch/pywps/pywps.cgi
>> All the best
>> Horst
>> Dr. Horst Düster
>> Burchacker 6
>> CH-4556 Aeschi
>> Tel.: +41 (0) 62 961 03 74
>> Mobil: +41 (0) 76 408 51 06
>> eMail: horst.duester at kappasys.ch
>> skype: horstduester
>> Web: www.kappasys.ch
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hello Horst and thanks for this great news.
> I tested the demo server using this data [1], but every process gives me an
> error of "'not well-formed (invalid token): line 7, column 6716".
> All the best
> Luca
> [1]http://dl.dropbox.com/u/348430/test.tar.gz
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Announcement-QGIS-WPS-Client-major-upgrade-tp6709261p6710800.html
> Sent from the qgis-user mailing list archive at Nabble.com.
Dr. Horst Düster
Burchacker 6
CH-4556 Aeschi
skype: horstduester
