[Qgis-user] python error in opening
Dave Panitz
davepanitz at yahoo.com
Mon Aug 22 11:10:13 PDT 2011
OK, will do - thanks again.
D
On Mon, Aug 22, 2011 at 11:05 AM, William Kyngesburye <woklist at kyngchaos.com
> wrote:
> OK, good to know, I'll fix the framework installers soon. Another one you
> should remove: sqlite.pth (leaving sqlite-py2.6.pth).
> On Aug 22, 2011, at 11:38 AM, Dave Panitz wrote:
> > That worked.
> > Many thanks William!
> > -Dave
> > On Mon, Aug 22, 2011 at 10:27 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > It worked when I tested it, though I may not have updated GDAL (it's just
> a repackaging). The only odd thing I see is that it looks like the old
> gdal.pth is left behind, which points to the old location I had the
> gdal-python stuff. Maybe this is confusing python (there's nothing there).
> Try deleteing
> > /Library/Python/2.6/site-packages/gdal.pth
> > (but not gdal-py2.6.pth). ...Just a wild guess really.
> > On Aug 22, 2011, at 10:57 AM, dpan wrote:
> > > Hi,
> > > I'm getting the same error after having installed the latest packages
> in
> > > Snow Leopard:
> http://osgeo-org.1803224.n2.nabble.com/file/n6712115/Screen_shot_2011-08-22_at_9.54.29_AM.png
> > > ...and wonder if anyone can help.
> > > Here is the full error text:
> > > Couldn't load plugin GdalTools due an error when calling its
> classFactory()
> > > method
> > > Traceback (most recent call last):
> > > File
> "/Applications/QGIS-1.8.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> > > line 138, in startPlugin
> > > plugins[packageName] = package.classFactory(iface)
> > > File
> "/Applications/QGIS-1.8.app/Contents/MacOS/../Resources/python/plugins/GdalTools/__init__.py",
> > > line 32, in classFactory
> > > from GdalTools import GdalTools
> > > File
> > > line 283, in _import
> > > mod = _builtin_import(name, globals, locals, fromlist, level)
> > > File
> "/Applications/QGIS-1.8.app/Contents/MacOS/../Resources/python/plugins/GdalTools/GdalTools.py",
> > > line 39, in
> > > raise ImportError( error_str )
> > > ImportError: No module named _gdal
> > > Python version:
> > > 2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
> > > [GCC 4.2.1 (Apple Inc. build 5646)]
> > > QGIS version:
> > > 1.8.0-Trunk Trunk, 7f611e9
> > > Python path:
> > > ['/Applications/QGIS-1.8.app/Contents/MacOS/../Resources/python',
> > > '/Users/dpanitz/.qgis/python', '/Users/dpanitz/.qgis/python/plugins',
> '/Applications/QGIS-1.8.app/Contents/MacOS/../Resources/python/plugins',
> > > '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
> > > '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.6',
> > > '/Library/Python/2.6/site-packages/numpy-override',
> > > '/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages',
> '/Library/Frameworks/GDAL.framework/Versions/1.8/Python/2.6/site-packages',
> > > '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
> > > '/Library/Python/2.6/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode',
> '/Applications/QGIS-1.8.app/Contents/Resources/python/plugins/fTools/tools']
> > > Thanks!
> > > Dave
> > > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/python-error-in-opening-tp6456668p6712115.html
> > > Sent from the qgis-user mailing list archive at Nabble.com.
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "I ache, therefore I am. Or in my case - I am, therefore I ache."
> > - Marvin
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
> that remind me of? Ah, yes - life."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110822/47a835b4/attachment.html>
