[Qgis-user] Announcing Metatools plugin
maning sambale emmanuel.sambale at gmail.com
Tue Aug 23 02:32:14 PDT 2011
Editing is OK, viewing metadata I get this:
Viewer can't be loaded: <type 'exceptions.ImportError'> No module
named QtXmlPatterns!
Using qgis 1.7 on mac leopard
On Tue, Aug 23, 2011 at 5:19 PM, Alexander Bruy
<alexander.bruy at gmail.com> wrote:
> Hi,
> 2011/8/22 maning sambale <emmanuel.sambale at gmail.com>:
>> I can edit and add metadata but I cannot view existing metadata.  I
>> get this error:
>> "Plugin can't be loaded: Qt version must be higher than 4.6.0!
>> Currently running: 4.7.3"
>> Looking forward to the Dublin Core template.
> Can you test 0.1.13 version? We add some changes that probably
> should fix this issue.
> Thanks
> Alexander Bruy
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
