[Qgis-user] OpenStreetMap import
Mayeul Kauffmann mayeul.kauffmann at free.fr
Mon Aug 29 12:29:26 PDT 2011
There is virtually an unlimited number of key=value pairs in OSM.
Partly because key and values are absolutely free; partly because even
mappers who try to follow guidelines make typing errors.
You will need hundreds of columns to create columns for each key.
The best solution I am aware of is to filter features (in QGIS) based on
a full text representation of the tags.
You can get this:
http://www.qgis.org/wiki/OpenStreetMap_data_rendered_with_QGIS
I have developed a tool to prepare the data for use in QGIS, see:
http://wiki.openstreetmap.org/wiki/Osm2postgresql
See also:
http://www.qgis.org/wiki/Using_OpenStreetMap_data
I also created tools to make a statistical analysis of the frequency of
tags, and used this to fine tune my styles. FOr a demo, see:
http://www.youtube.com/watch?v=NBBYtH2svw0
For my styles:
http://wiki.openstreetmap.org/wiki/Osm2postgresql#See_also
Mayeul
Le lundi 29 août 2011 à 18:07 +1000, Mick a écrit :
> I am endeavouring to build a set of layers to cover Devon from an
> historic perspective to illuminate my family's residence in the county
> from before 1600 through to about 1850 and also my interest in
> archaeology.
> I have found some useful information in the OpenStreetMap project's
> online mapping.
> While I have been able to import the OSM data into QGIS the somewhat
> anarchic application of tags in the data leaves substantial amounts of
> manual editing before I can start extracting the data I am after.
> My thought is that if the OSM import utility would create columns for
> each tag that appears in the data it would make the task much easier.
> Does this facility exist?
> mick
> Qgis-user mailing list
