[Qgis-user] editable attribute tables
Andreas Neumann
a.neumann at carto.net
Wed Aug 17 10:34:18 EDT 2011
Hi Andrew,
With ESRI shapefiles you can edit the attribute table and add and
delete columns. However, you cannot re-arrange the order of the columns,
as far as I know. The table can be sorted - per default is is sorted by
the primary key column.
Andreas
On Wed, 17 Aug 2011 09:00:20 -0500, Andrew Novak wrote:
> Is it possible to create shapefiles with editable attribute tables? I
> need to add multiple rows and have columns that I can delete and move
> around.?.?
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
