[Qgis-user] ArcGIS 10 and QGIS 1.7
Andreas Neumann
a.neumann at carto.net
Thu Aug 25 03:16:53 EDT 2011
I don't think that QGIS' ArcGIS' python installations get into their
ways. I think they both bring along their own local python
installations. Do you have any indication that the two interfere with
each other or is it just an assumption?
It is quite common that machines have multiple python installations in
parallel.
Andreas
On Thu, 25 Aug 2011 08:51:46 +0200, Frank Sokolic wrote:
> Hi Christine,
> I recently had a problem on Windows XP when I uninstalled 1.7,
> installed and uninstalled 1.6, and then installed QGIS 1.7 again.
> QGIS
> 1.7 kept on crashing and I eventually traced the problem to Trolltech
> keys in the registry. After removing Trolltech from the registry and
> then reinstalling 1.7 everything worked again.
> Regards, Frank.
> FROM: c.schmidt at geoTguide.de
> SENT:2011-08-24 21:48:16
> TO: qgis-user at lists.osgeo.org
> CC:
> SUBJECT: [Qgis-user] ArcGIS 10 and QGIS 1.7
> Good evening all,
> have recently installed QGIS 1.7 on a Windows XP machine. It works
> really fine and I havn't met any difficulty until now. Thanks to this
> really engaged community ...
> Should install a time limited version of ArcGIS 10 for educational
> purposes now on the same machine. Should have better done this in
> another succession, I know. Remember some troubles mentioned in this
> list with ArcGIS beeing installed after QGIS, as ArcGIS also uses
> Python.
> Because I am now in worry about my clean QGIS installation, I am
> considering to uninstall QGIS 1.7, then install ArcGIS 10 and after
> all install QGIS 1.7 again.
> May I expect the uninstall process of QGIS beeing complete enough not
> to get another trouble after a second installation of QGIS 1.7 ?
> Thanks for an advice,
> and regards,
> Christine
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
