[Qgis-user] converting espg 4326
steve sgalowski
steve.sgalowski at gmail.com
Thu Dec 1 00:42:17 PST 2011
ty for your help andreas , but the program i have on my pda , does not
accept this type of shap file espg 4326 , but it accepts shape files
from cloud made but only some
Stephen
On 01/12/2011, Andreas Neumann <a.neumann at carto.net> wrote:
> hm - what do you mean by that? EPSG 4326 is just one projection format
> (like thousands of other projections). All shapefile readers should be
> able to deal with it.
> In QGIS, when you save to a Shapefiles you can even select the target
> projection and it will automatically project the data for you.
> Hope this helps,
> Andreas
> On Thu, 1 Dec 2011 18:31:10 +1000, steve sgalowski wrote:
>> is there away to convert espg 4326 to standard shp files , that
>> programs can use ?
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
