[Qgis-user] Qgis-web-client: apache config
Andreas Neumann
a.neumann at carto.net
Mon Dec 5 23:31:56 PST 2011
Yes - it was decided to have some out of the box project where global
searching should work through Geonames.
Andreas
On Tue, 6 Dec 2011 08:12:40 +0700, Arif Arham wrote:
> Understood. Thanks!
> You know what? I skip those steps for now just to see how my map
> looks
> in the new qgis-web-client, and found some thing new! What I did was:
> * copying GlobalOptions.js.templ-4326 to GlobalOptions.js;
> * setting var serverAndCGI into
> "http://localhost/cgi-bin/qgis_mapserv.fcgi [3]"; and
> * displaying my map
> at http://localhost/qgis-web-client/site/qgiswebclient.html?map=/home/arif/mymap/test.qgs
> [4]
> * here is the best thing: searching is working! It uses Geonames
> database (isn't?) to search any places.
> -Arif
> ___________________________
> KhazanahArham.wordpress.com [5]
> On Mon, Dec 5, 2011 at 5:37 PM, Mathias Walker wrote:
>>> I try to install the new update of Qgis-web-client. However, at
>> "For the
>> > Terminally Lazy", after reloading the Apache I found this error:
>> > Syntax error on line 38 of
>> > /etc/apache2/sites-enabled/qgis-web-client.conf:
>> > Invalid command 'RewriteCond', perhaps misspelled or
>> defined by
>> > a module not included in the server configuration
>> > Action 'configtest' failed.
>> > The Apache error log may have more information.
>> > ...fail!
>> > This is what in line 38:
>> > RewriteCond %{QUERY_STRING} ^(?:.*)query=samplesearch&*(?:.*)$
>> > Is it okey to ignore it?
>> The RewriteCond is optionally used for the search panel of the QGIS
>> web-
>> client. The RewriteRules are used for nicer URLs to the QGIS maps
>> and web-
>> client files.
>> You have to enable the Apache 'mod_rewrite' module on your system,
>> so it can
>> use the 'RewriteCond' and 'RewriteRule' commands.
>> Best regards
>> Mathias Walker
>> Sourcepole - Linux & Open Source Solutions
>> Churerstrasse 22, 8808 Pfäffikon SZ, Switzerland
>> Tel: 044 440 77 11 Fax: 044 440 77 12
>> mwa at sourcepole.ch [1] http://www.sourcepole.ch [2]
> Links:
> [1] http://sourcepole.ch
> [2] http://www.sourcepole.ch
> [3] http://localhost/cgi-bin/qgis_mapserv.fcgi
> [4]
> [5] http://khazanaharham.wordpress.com
> [6] mailto:mwa at sourcepole.ch
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
