Re : [Qgis-user] WFS Transactions to GeoServer freeze QGIS
Yves Jacolin yjacolin at free.fr
Sat Dec 10 00:29:36 PST 2011
I have successfully updated data from geoserver wfs in localhost. I had same issue than you with a remote server. But it was a special infrastructure with à CAS for security.
Other people said that they get some error message but the modification have been saved. Geoserver used in this case is also à special use of Geoserver with CAS.
Regard,
Y.
----- Reply message -----
De : "Gis Mage" <gismage at gmail.com>
Pour : <qgis-user at lists.osgeo.org>
Objet : [Qgis-user] WFS Transactions to GeoServer freeze QGIS
Date : ven., déc. 9, 2011 11:11
Hi list!
I would like to know if anyone has any luck editing wfs layers
published with geoserver?
I have the following situation:
First I connect to a geoserver wfs service and get a list of layers.
Then I add a layer topp:states to the map (this is one of the
shapefiles, which comes by default with geoserver)
I turn on editing and add one polygon to the layer. The poly is added
ok and the attributes are filled ok to.
When I hit Save edits QGIS freezes forever with 100% processor load
and nothing happens.
Looking through geoserver log I don't see any request for wfs
transaction. So I assume it's a qgis bug.
When I'm editing the same layer with uDig, transactions work ok and I
see the corresponding messages in the geoserver log.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111210/c9f97616/attachment.html>
