[Qgis-user] Re: Problem readingn geotif file with qgis 1.7.3
Carlos Cerdán
sig.upagu at gmail.com
Tue Dec 13 12:51:28 PST 2011
Same problem (WARNING ! libtiff version mismatch : You're linking
against libtiff 3.X but GDAL has been compiled against libtiff >= 4.0.0,
another solution (Ubuntu 11.10): Uninstall libgdal1-1.6.0 (and all
dependencies).
I had installed both gdal 1.6 and 1.8 (because automatic update) and 1.6
was the problem.
Carlos
El 13/12/11 08:31, Agustin Lobo escribió:
> The problem is caused by a faulty libgdal1-1.8.0 in ubuntugis-unstable
> A solution has been suggested by Julien Malik
> (see http://orfeo-toolbox.org/otb/) as he had had this problem few weeks ago
> and actually made a correctly build libgdal for otb.
> The solution is:
> 1. Make sure you have the otb repo in your list:
> http://ppa.launchpad.net/otb/orfeotoolbox-stable-ubuntugis/ubuntu
> (in my case, lucid)
> 2. Run
> sudo aptitude install libgdal1-1.8.0=1.8.0-2~lucid2+otb2
> libgdal1-dev=1.8.0-2~lucid2+otb2
> 3. Start QGIS. The tif files can be read and displayed again.
> Now I have libgdal1-1.8.0 flagged as upgradeable in Synaptic, but will
> not do it until the
> package is fixed there.
> Thanks a lot Julien!
> Agus
> 2011/12/12 Agustin Lobo<alobolistas at gmail.com>:
>> Just upgraded to qgis 1.7.3 using the ubuntugis-unstable repo
>> and cannot open geotif files:
>> /media/Iomega_HDD/MASTER_ICTA2007_2008/GEODATA_miniprojs/mtc250/mtc250v5f1r01.tif
>> is not a supported raster data source
>> WARNING ! libtiff version mismatch : You're linking against libtiff
>> 3.X but GDAL has been compiled against libtiff>= 4.0.0
>> My gdal is libgdal1-1.8.0, my libtiff4 is 3.9.2-2. Is this thus a
>> problem of having an old version of libtiff in ubuntugis?
>> Any advice on what I can do?
>> Thanks,
>> Agus
> Qgis-user mailing list
