[Qgis-user] Plagin google, vector layer changed latlot
Alex Mandel tech_dev at wildintellect.com
Sat Dec 17 11:56:31 PST 2011
On 12/17/2011 11:44 AM, SYAFRUDDIN RAUF wrote:
> Hello,
>  Sir!  Could you help me
> I have  layers with latitude longitude are
> 119.4593,-5.2432 (metadata : In layer spatial reference system units :
> xMin,yMin 119.381,-5.2448 : xMax,yMax 119.52,-5.10252,. Layer Spatial Reference
> System:   (proj=longlat +datum=WGS84 +no_defs) . If  I
> plugin with google, , the map appears but  latitude longitude
> changed  become 13289635,-586183,. I used OS windows XP.
> (picures).
> If somebody has an easy solution for this, please let me
> know.
> Syafrauf
The plugins that overlay data with Google/Yahoo etc... require that the
map projection be set to Spherical Mercator, meters. That's why the
coordinates look different. If you need to extract values from that in
Lat/Lon WGS84 use the Coordinate Capture tool.
Thanks,
Alex
