[Qgis-user] RE: "Known Issues" list
Alister Hood alister.hood at synergine.com
Sun Dec 18 03:08:07 PST 2011
Hi guys,
> Date: Sat, 17 Dec 2011 21:07:01 +0100
> From: Agustin Lobo <alobolistas at gmail.com>
> Subject: [Qgis-user] Re: [Qgis-developer] Georeferencer produces wrong
> 	(shifted) result
> To: Manuel Massing <m.massing at warped-space.de>
> Cc: qgis-user <qgis-user at lists.osgeo.org>,
> 	qgis-developer at lists.osgeo.org
> Message-ID:
<CAG4NReJviifQzpGq7ZE2LqegTgpEWfCMvb5QGmJSDc10+HATXQ at mail.gmail.co
> m>
> Content-Type: text/plain; charset=ISO-8859-1
> Many thanks Manuel.
> No hurry for including the patch, once the problem is identified and
> you even provide a simple way to circumvent it.
> What is needed is to have users know of these potential problems, ie.
> through
> a note of "Known Problems" included in the release mentioning that
> "the Georeferencer plugin requires users to check that their files do
> not include
> an implicit geotransform and use e.g.
> "gdal_translate -co "PROFILE=BASELINE" -of GTiff Ilerfly125v2.tif
> Ilerfly125v2-nogeotrans.tif"
> to remove it in case this is actually needed".
> In other words, once the problem is identified and warned, users can
> rely on using the software for the rest of cases.
> The question is thus that, in addition of the excellent developers
> already involved,
> we need a team of users and a battery of tests to be regularly
> performed.
> Agus
> Date: Sat, 17 Dec 2011 21:12:23 +0100
> From: Werner Macho <werner.macho at gmail.com>
> 	(shifted) result
> To: Agustin.Lobo at ija.csic.es
> Cc: Manuel Massing <m.massing at warped-space.de>,
> 	qgis-developer at lists.osgeo.org,	qgis-user <qgis-
> Message-ID:
> 	<CA+3oMjv8y7v8kx_A0bKeK-
> VMQMej6GEWuWorDNM4BCfFqAOPsg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Very good idea..
> Implementing a known problems per release seems possible to me. But it
> can
> only be a webpage cause at the time of release you mostly are not
aware
> of
> the problems..
> Regards
> Werner
Do you think a _wiki_ page would be a good idea, so that more people can
add things to it?
Alister
