[Qgis-user] Hi everybody
Giacomo Fontanelli
giacomofontanelli at yahoo.it
Tue Dec 27 07:09:00 PST 2011
Hi, I'm Giacomo Fontanellin from Florence, Italy.
I'm a PhD for University of Basilicata, I work on remote sensing of environment.
I'm quite new with QGis, buti I like it, cause it's very easy to use and user-friendly.
This is my problem:
I've got many shape file in a project, each of those with different projections, but I still can visualize the polygons in the right position.
The spatial extension of the files is almost the same and is defined in meters: example: xMin, yMin 1714882.75,4845790.12 : xMax,yMax 1735233.69,4861856.86.
Unfortunally I've got a layer with the spatial extension defined in degrees: xMin, yMin 10.94,43.7388 : xMax,yMax 11.7543,43.9773, and I can't visualize it in the correct location.
How can I change the extension of the files from degrees to meters and viceversa?
Thank you very much and sorry for my english
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111227/847eb32c/attachment.html>
