[Qgis-user] Re: Qgis-user Digest, Vol 70, Issue 61
dan laurentiu stoica
dan_sezu at yahoo.com
Thu Dec 29 23:14:39 PST 2011
Thanks for support to Paolo Cavallini - Faunalia !
Can you give some detailed steps for OTB plugin in GRASS ?
Bets regards,
Dan
From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
To: qgis-user at lists.osgeo.org
Sent: Thursday, December 29, 2011 12:33 PM
Subject: Qgis-user Digest, Vol 70, Issue 61
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: Add new template to the composer (Marco Hugentobler)
2. Re: New Labeling: conditional labels (Giuseppe Sucameli)
3. GRASS plugin instability on Windows? (Paolo Cavallini)
4. fragstat question (dan laurentiu stoica)
5. Re: fragstat question (Paolo Cavallini)
6. Re: Add new template to the composer (Paolo Cavallini)
7. Re: GRASS plugin instability on Windows? (Alexander Bruy)
8. Re: New Labeling: conditional labels (Andreas Neumann)
9. Re: GRASS plugin instability on Windows? (Paolo Cavallini)
10. Re: New Labeling: conditional labels (Paolo Cavallini)
11. Re: New Labeling: conditional labels (Nathan Woodrow)
Message: 1
Date: Wed, 28 Dec 2011 19:05:41 +0100
From: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
Subject: Re: [Qgis-user] Add new template to the composer
Message-ID: <4EFB5A75.2070601 at sourcepole.ch>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hi Yves
Add a new directory called 'composer_templates' into /usr/share/qgis and
save template files into it ('Save as template' in print composer
window). The composermanager creates a new entry for each template in
that directory.
Btw, that functionality was developed for the edugeo project ;-)
Regards,
Marco
On 28.12.2011 16:52, Yves Jacolin wrote:
> Hello,
> When I open the composer manager, there is a dropdown list to choose the
> template for the new composer. There is always one item and I can't see how to
> change this (add a new template for instance).
> Furthermore, easyPrint use a specific template that don't fit for everybody need
> and therefore this plugins is not so usefull.
> Do you know any way to create template for the composer?
> Thanks,
> Y.
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
Message: 2
Date: Wed, 28 Dec 2011 20:01:43 +0100
Subject: Re: [Qgis-user] New Labeling: conditional labels
To: Andreas Neumann <a.neumann at carto.net>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Message-ID:
<CAA6k8-+6Jc_+H3bjE2n15aRXtsKpLoi9NTZCiG7Y8C--qjbEtQ at mail.gmail.com>
Hi Andreas,
On Thu, Dec 22, 2011 at 2:31 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> What I want is that a label is only drawn if a column value is larger than
> 0. I don't want to label features with a value of zero.
> Do you have any hints how the syntax works for such a case? I see ">"
> operators but no "if" or "when".
there's no "if" operator, but ">" returns 1 if true and 0 if false,
e.g. (field > 5)*10 let's give you 10 or 0 as result.
The problem is that you don't want to display anything when
the field value is 0, so we can use the substr function.
Here's the solution to your problem:
substr(id, 0, (id > 0)*-1)
that means if id <= 0 then substr(id, 0, 0) else substr(id, 0, -1)
In general:
substr(output, 0, (condition)*-1)
Cheers.
> If it is not possible, then I can still do it in Postgis, but it would be
> nice being able to do this in QGIS.
> Thanks for any hints,
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
Giuseppe Sucameli
Message: 3
Date: Thu, 29 Dec 2011 07:43:50 +0100
Subject: [Qgis-user] GRASS plugin instability on Windows?
To: qgis-user <qgis-user at lists.osgeo.org>
Message-ID: <4EFC0C26.2030809 at faunalia.it>
Content-Type: text/plain; charset=UTF-8
Hi all.
I recently had reports about some instability of the GRASS plugin on windows.
(Un)fortunately I cannot test it, as I do not own a win licence, so I'm asking here:
* is this a common problem?
* can be related to anything specific?
- Win version
- installed software
- does it happen on "dirty" installations only, or also on clean ones?
- antivirus?
* when (at what QGIS version) has the problem arisen?
Thanks a lot.
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Message: 4
Date: Thu, 29 Dec 2011 00:36:33 -0800 (PST)
Subject: [Qgis-user] fragstat question
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Message-ID: <1325147793.7553.YahooMailNeo at web33807.mail.mud.yahoo.com>
Content-Type: text/plain; charset="us-ascii"
Does anyone have some hints for the use of Fragstat with Q GIS ?
Dan
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20111229/b5949e53/attachment-0001.html
Message: 5
Date: Thu, 29 Dec 2011 09:55:13 +0100
Subject: Re: [Qgis-user] fragstat question
Message-ID: <4EFC2AF1.5070700 at faunalia.it>
> Dan
Hi Dan [I already sent this, did you receive it?].
AFAIK there is nothing like Fragstat ready-made in QGIS. You have two routes:
- r.li (GRASS module), not yet implemented in QGIS, you'll need GRASS
- OTB plugin (methods should be added for the analyses you need).
All the best.
www.faunalia.eu
Message: 6
Date: Thu, 29 Dec 2011 10:54:06 +0100
Message-ID: <4EFC38BE.7040609 at faunalia.it>
Il 28/12/2011 19:05, Marco Hugentobler ha scritto:
> Hi Yves
> Add a new directory called 'composer_templates' into /usr/share/qgis and save
> template files into it ('Save as template' in print composer window). The
> composermanager creates a new entry for each template in that directory.
Hi all.
Wouldn't it be better using the /home dir instead of /usr/share/qgis for this?
All the best.
www.faunalia.eu
Message: 7
Date: Thu, 29 Dec 2011 12:22:50 +0200
Subject: Re: [Qgis-user] GRASS plugin instability on Windows?
To: cavallini at faunalia.it
Message-ID:
<CALuHMPBEKdP_zEeCx+09AgGBFc8CQmiT9k+eymuzugtVZfe+Tg at mail.gmail.com>
I can confirm problems with output messages encoding [0] under
32 bit Windows XP Pro SP3, 32 and 64 bit Windows 7. This happen
on clean and dirty installations and seems not releated to any
specific software.
[0] http://hub.qgis.org/issues/3164
2011/12/29 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> - Win version
> - antivirus?
> Thanks a lot.
Alexander Bruy
Message: 8
Date: Thu, 29 Dec 2011 11:25:38 +0100
To: Giuseppe Sucameli <sucameli at faunalia.it>
Message-ID: <005bdda6961afb7b0722c7f96daca412 at carto.net>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Giuseppe,
Thanks for your hint with the syntax - it works in my case.
I think I sort of understand the syntax - at least the > operator and
the substr. What I do not understand is why I need the *-1 (multiplier).
But I think the syntax is far from being intuitive, without some help.
Maybe we can come up with a simple solution in the future?
If we could combine the rule-based renderer approach with the current
labeler (with its new query builder), it would be awesome.
Thanks for your help!
Andreas
On Wed, 28 Dec 2011 20:01:43 +0100, Giuseppe Sucameli wrote:
> Hi Andreas,
>> larger than
> In general:
> Cheers.
>> would be
>> Andreas
>> Andreas Neumann
>> Switzerland
Andreas Neumann
Switzerland
Message: 9
Date: Thu, 29 Dec 2011 11:25:09 +0100
To: Alexander Bruy <alexander.bruy at gmail.com>
Message-ID: <4EFC4005.5040503 at faunalia.it>
> specific software.
Thanks for feedback - but this does not ionvolve any instability, right?
All the best.
www.faunalia.eu
Message: 10
Date: Thu, 29 Dec 2011 11:27:51 +0100
Message-ID: <4EFC40A7.7000108 at faunalia.it>
Il 29/12/2011 11:25, Andreas Neumann ha scritto:
> If we could combine the rule-based renderer approach with the current labeler (with
Agreed, I think we must use the same approach everywhere (renderer, field calculator,
raster calculator, actions), and the labelling approach is the best IMHO. Others are
often a bit geeky.
All the best.
www.faunalia.eu
Message: 11
Date: Thu, 29 Dec 2011 20:33:07 +1000
Cc: qgis-user <qgis-user at lists.osgeo.org>, Giuseppe Sucameli
Message-ID:
<CAAi8Yg9A_9zZD3WVDyOgJqrpRZYyoMJr4mFZYZcJqfsmkggMvw at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
It would be handy to add condition statements to QgsExpression so we can
support this kind of thing, Martin would be the guy to talk to about adding
this kind of thing. He knows the most about QgsExpression.
I am also looking at adding Python support to any sections that also use
QgsExpression; this would allow us to use a QGIS expression for simple-ish
stuff but also Python if need be for doing more powerful stuff.
I started a wiki page[0] before the last Hackfest about some of my ideas
about adding rule based labeling, which would be very cool to have.
[0] http://hub.qgis.org/wiki/quantum-gis/RuleBasedLabelingIdeas
- Nathan
On Thu, Dec 29, 2011 at 8:25 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Giuseppe,
> I think I sort of understand the syntax - at least the > operator and the
> Andreas
>> Hi Andreas,
>>> than
>> In general:
>> Cheers.
>>> Andreas
>>> Andreas Neumann
>>> Switzerland
>>> ______________________________**_________________
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Andreas Neumann
> Switzerland
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20111229/d362fa83/attachment.html
End of Qgis-user Digest, Vol 70, Issue 61
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111229/3dfb7e29/attachment.html>
