Fwd: [Ubuntu] Fwd: [Qgis-user] Re: Problem readingn geotif file with qgis 1.7.3
Agustin Lobo alobolistas at gmail.com
Tue Dec 13 16:17:10 EST 2011
---------- Forwarded message ----------
Date: 2011/12/13
Subject: Re: [Ubuntu] Fwd: [Qgis-user] Re: Problem readingn geotif
To: ubuntu at lists.osgeo.org
FYI the patch that we have for gdal 1.8.0 is here :
http://hg.orfeo-toolbox.org/OTB-DevUtils/file/ef64ddb5b440/Packaging/ubuntu/gdal/do_not_disable_GTIFF_for_otb
and is not necessary for gdal 1.8.1
The problem appears because somehow you are using in Qgis a package
that links to libtiff (maybe from one of the python module loaded in
Qgis).
Julien
Le 13/12/2011 15:28, Etienne Tourigny a écrit :
> Hi list,
> forwarding this thread because it relates to ubuntugis.
> I'd also like to ask, why is ubuntugis-unstable still using
> gdal-1.8.0, as 1.8.1 was released in July?  It uses the same gdal
> version as ubuntugis-stable.
> regards,Etienne
> From: Agustin Lobo<alobolistas at gmail.com>
> Date: Tue, Dec 13, 2011 at 11:31 AM
> Subject: [Qgis-user] Re: Problem readingn geotif file with qgis 1.7.3
> To: qgis-user<qgis-user at lists.osgeo.org>, qgis-developer
> <qgis-developer at lists.osgeo.org>
> The problem is caused by a faulty libgdal1-1.8.0 in ubuntugis-unstable
> A solution has been suggested by Julien Malik
> (see http://orfeo-toolbox.org/otb/) as he had had this problem few weeks ago
> and actually made a correctly build libgdal for otb.
> The solution is:
> 1. Make sure you have the otb repo in your list:
> http://ppa.launchpad.net/otb/orfeotoolbox-stable-ubuntugis/ubuntu
> (in my case, lucid)
> 2. Run
> sudo aptitude install libgdal1-1.8.0=1.8.0-2~lucid2+otb2
> libgdal1-dev=1.8.0-2~lucid2+otb2
> 3. Start QGIS. The tif files can be read and displayed again.
> Now I have libgdal1-1.8.0 flagged as upgradeable in Synaptic, but will
> not do it until the
> package is fixed there.
> Thanks a lot Julien!
> Agus
> 2011/12/12 Agustin Lobo<alobolistas at gmail.com>:
>> Just upgraded to qgis 1.7.3 using the ubuntugis-unstable repo
>> and cannot open geotif files:
>> /media/Iomega_HDD/MASTER_ICTA2007_2008/GEODATA_miniprojs/mtc250/mtc250v5f1r01.tif
>> is not a supported raster data source
>> WARNING ! libtiff version mismatch : You're linking against libtiff
>> 3.X but GDAL has been compiled against libtiff>= 4.0.0
>> My gdal is libgdal1-1.8.0, my libtiff4 is 3.9.2-2. Is this thus a
>> problem of having an old version of libtiff in ubuntugis?
>> Any advice on what I can do?
>> Thanks,
>> Agus
> Qgis-user mailing list
> UbuntuGIS mailing list
> Ubuntu at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/ubuntu
> http://trac.osgeo.org/ubuntugis/wiki
