[Qgis-user] files dwg in QGIS
Andreas Neumann
a.neumann at carto.net
Mon Dec 19 15:23:38 EST 2011
no - unfortunately FDO does not support DWG files --> see
http://themapguyde.blogspot.com/2011/12/my-2010-mapguidefdo-wishlist-revisited.html
(item 6)
I guess Autodesk regards DWG as their "crown jewels" and therefore does
not support OS developement around DWG.
There is a FDO/OGR bridge, but unless FDO has some advantages over OGR -
why should one use it? DWG support in FDO would be one reason to look
into FDO.
Andreas
On 12/19/2011 08:50 PM, Brad Nesom wrote:
> I believe dwg is supported in the fdo library.
> I have often wondered what kept the qgis dev from using fdo?
> http://fdo.osgeo.org/OSProviderOverviews.html
> I do see some overlap but adding eliminating providers is a simple task
> (that even I can do).
> On Mon, Dec 19, 2011 at 1:14 PM, Even Rouault
> <even.rouault at mines-paris.org>wrote:
>> Le lundi 19 décembre 2011 13:11:12, Andreas Neumann a écrit :
>>> assuming you want to open DWG files in GIS?
>>> Currently it is not possible to read or write DWG files. QGIS uses OGR
>>> to read/write vector data and DWG is not on the list of supported
>>> formats. There is initial support for dxf (but with some issues).
>>> You can consider sponsoring the development of a DWG driver in OGR if
>>> you are interested in reading/writing these files. It would probably be
>>> based on other existing libraries.
>> There is a new driver for DWG based on the Open Design Alliance Teigha
>> Libraries (not FOSS AFAIK) in GDAL 1.9.0dev trunk. I don't know why it is
>> not
>> advertized on the OGR formats page, maybe beacause its status is still a
>> bit
>> experimental. Perhaps FrankW could confirm.
>>> Andreas
>>> On Mon, 19 Dec 2011 11:28:42 +0100, livreri wrote:
>>>> Salve!
>>>> Vorrei vedere dei files dwg in QGIS 1.7!
>>>> Come posso fare?
>>>> Grazie a tutti
>>>> S. Livreri Console
>>>> Hello!
>>>> I wish to see some DWG files in QGIS 1.7!
>>>> How can I do it?
>>>> Thank you all
>>>> S. Livreri Console
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
