[Qgis-user] Multiple map windows
razmjooeis at faunalia.co.uk razmjooeis at faunalia.co.uk
Fri Feb 4 07:34:07 PST 2011
Excellent work.
Is is possible to lock the view on the mirrored one. At the moment, if I
zoom/pan in the main canvas, it changes the view on the mirrored canvases.
Cheers
Sab
> Hi all,
> On Thu, Feb 3, 2011 at 12:22 PM, cavallini at faunalia.it <
> cavallini at faunalia.it> wrote:
>> We (faunalia) are doing something simple on this. In the next days we'll
>> release a plugin.
> Faunalia are pleased to announce the "DockableMirrorMap" plugin.
> You can find it in the Faunalia repository.
> It's a experimental plugin, so remember to turn on the experimental
> plugins
> otherwise you cannot see it.
> Every time you run the plugin, a dockable mirror canvas will be added to
> the
> main
> windows. Once added, you are able to resize and move it in the position
> you
> prefer.
> There are 2 buttons for each mirror canvas:
> the first add the current selected layer in the legend to the mirror
> canvas,
> the second remove it.
> All canvases are extents and CRSs synchronized.
> Feedbacks and comments are very welcome!
> Regards.
> ----- Reply message -----
>> Da: "Nathan Woodrow" <madmanwoo at gmail.com>
>> Data: gio, feb 3, 2011 12:12
>> Oggetto: [Qgis-user] Multiple map windows
>> A: "Kris Nackaerts" <knackaerts at gmx.net>
>> Cc: <qgis-user at lists.osgeo.org>
>> Hi,
>> I think/hope they are on the todo list.  A lot of things need to be
>> worked
>> out before they could be added, things like "What happens when the user
>> does
>> X with more then one window".   I had a look at the code today thinking
>> the
>> same thing and there would need to be a lot of code rewrite in order for
>> it
>> to work correctly and smoothly as QGIS is coded to only work with one
>> window.
>> I think it is doable but not sure when or who will do it.
>> It is something that I would really really like to see at some stage in
>> the
>> future.
>> - Nathan
>> On Thu, Feb 3, 2011 at 9:06 PM, Kris Nackaerts <knackaerts at gmx.net>
>> wrote:
>>> Dear,
>>> Does anyone know if (optionally geographically synchronised) multiple
>>> map
>>> windows are / will be supported in QGIS?
>>> I've seen some discussion on this topic on the list in the past.
>>> Kris
>>> Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
>>> belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
