[Qgis-user] Problem with version sip module
Noli Sicad nsicad at gmail.com
Fri Feb 4 16:55:43 PST 2011
Try to use the compatible python-qgis with qgis.
if not, try the trunk.
http://www.qgis.org/wiki/Download#Ubuntu
Noli
On 2/5/11, Rainer M Krug <r.m.krug at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> after not using qgis for some time and several ypgrades inbetween, I get
> the following eror message when starting qgis:
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> RuntimeError: the sip module implements API v8.0 but the qgis.core
> module requires API v7.1
> Python version:
> 2.6.6 (r266:84292, Sep 15 2010, 16:02:57)
> [GCC 4.4.5]
> QGIS version:
> 1.6.0-Trunk 'Trunk', exported
> Python path:
> ['/usr/share/qgis/python', '/home/rkrug/.qgis/python',
> '/home/rkrug/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload',
> '/usr/local/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode']
> The version of python-sip which is installed is:
> 4.11.2-0ubuntu1~maverick1~ppa1
> I am running Maverick, all updates.
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Natural Sciences Building
> Office Suite 2039
> Stellenbosch University
> Main Campus, Merriman Avenue
> Stellenbosch
> South Africa
> Tel:        +33 - (0)9 53 10 27 44
> Cell:       +27 - (0)8 39 47 90 42
> Fax (SA):   +27 - (0)8 65 16 27 82
> Fax (D) :   +49 - (0)3 21 21 25 22 44
> Fax (FR):   +33 - (0)9 58 10 27 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk1MJD0ACgkQoYgNqgF2egqAswCdEzqEleJoC6ig7Byk2J1WHyQs
> fqAAnRLd96tdbRywyap790dueOQBm6gr
> =800d
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
