[Qgis-user] Re: Issue with map units on scale bar (wgs84 prj) (qgis 1.6, win xp)
hayamaguchi hayamaguchi at gmail.com
Fri Feb 11 16:20:51 PST 2011
Hi, Percy.  If your map unit is in meters (m) but want your scale bar to
display kilometers (km), one way to do this in Composer would be to set some
parameters in the "Scale bar" dialogue (under the "Item" tab when you have
the scale bar selected).
Assume that you want your scale bar to show one kilometer only.  You can set
the "Segment size (map units)" to be 1000, and the "Map units per bar unit"
to be 1000 as well.  Set "1 Right segments" and "0 Left segments."  That
should give you a scale bar with one tick equivalent to 1 kilometer in
length.
Finally, set the "Unit label" to "Kilometer" or "km" or something like that.
I hope it works for you!
Howard Yamaguchi
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Issue-with-map-units-on-scale-bar-wgs84-prj-qgis-1-6-win-xp-tp6015194p6017698.html
Sent from the qgis-user mailing list archive at Nabble.com.
