[Qgis-user] MMQGIS plugin - Color Map error
Noli Sicad nsicad at gmail.com
Sun Feb 13 03:06:10 PST 2011
Hi Cameron,
Try to create a "tmp" directory,  then save "mmqgis.qml" file first.
'/tmp/mmqgis.qml'
Then, this error will go away, I think.
I have similar problem with mmqgis before.
Noli
On 2/13/11, Cameron Munro <cameron.munro at yahoo.com> wrote:
> I'm running QGIS1.6 and Win7. The mmqgis plugin package is terrific, except
> I
> get an error when I try color map (below), seems not to be able to find
> mmqgis.qml. Does anyone else experience this issue, and if so is there a
> solution/workaround? I've tried reinstalling the plugin without success, and
> have observed the same issue trying it in QGIS1.5.
> Cheers
> Cameron.
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File "C:/Users/Cameron/.qgis/python/plugins\mmqgis\mmqgis_dialogs.py",
> line
> 292, in run
>     int(self.highcolor.palette().color(QPalette.Normal,
> QPalette.Button).rgb()))
>   File "C:/Users/Cameron/.qgis/python/plugins\mmqgis\mmqgis_library.py",
> line
> 251, in mmqgis_set_color_map
>     outfile = open(temp_filename, 'w')
> IOError: [Errno 2] No such file or directory: '/tmp/mmqgis.qml'
> Python version:
> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> <snip>
> Qgis-user mailing list
