[Qgis-user] Legend orientation
Alister Hood
alister.hood at synergine.com
Mon Feb 14 02:38:09 PST 2011
Hi guys,
There is the "horizontal legend" request
https://trac.osgeo.org/qgis/ticket/1841
and the "column wrapping in legend" request
https://trac.osgeo.org/qgis/ticket/1505
These might not be exactly what you're talking about, but they might
be similar enough that the functionalities each of you want could
all be achieved; if some thought is put into how to do it.
Regards,
Alister
> Date: Mon, 14 Feb 2011 08:18:56 +0100
> From: Paolo Cavallini <cavallini at faunalia.it>
> Subject: Re: [Qgis-user] Legend orientation
> To: Andreas Neumann <a.neumann at carto.net>
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <1297667936.3428.11.camel at ursus.ufficio.net>
> Content-Type: text/plain; charset="UTF-8"
> > This is currently not possible. You can do it "manually" though. You
> can
> > use three times the same legend and manually remove the entries that
> are
> > in the other two columns. Not so elegant, I know, but at least a
> > workaround now.
> Brett:
> could you please check whether there is an open ticket on this, and if
> not opening it?
> Thanks.
> http://www.faunalia.it/pc
