[Qgis-user] Re: Qgis-user Digest, Vol 60, Issue 21
Ramon Andinach custard at westnet.com.au
Mon Feb 14 20:53:21 PST 2011
On 15/02/2011, at 12:12, "Alister Hood" <alister.hood at synergine.com> wrote:
> Hi Ramon,
>> Date: Tue, 15 Feb 2011 09:46:09 +0800 (WST)
>> From: custard <custard at westnet.com.au>
>> Subject: [Qgis-user] Delimited Text Plug-in claiming text file not
>>    valid
>> To: qgis-user at lists.osgeo.org
>> Message-ID:
>>    <550194667.539501297734369648.JavaMail.root at zim-
>> store03.web.westnet.com.au>
>> Content-Type: text/plain; charset="utf-8"
>> Hi,
>> I like the revamp of the Delimited Text Plugin in trunk - it feels
> much
>> easier to use.
>> However...
>> While opening a file today I noticed that I didn't get an oppertunity
>> to define a CRS for the file - which I used to in 1.6.
>> Before reporting that I thought I'd update trunk (which is now
> revision
>> 15172) and am getting a completly different error from the same file.
>> It says:
>> The layer M:/Data/WesternAustralia/SH51-
> 09/Anthill/MMAnthill/Exports/20110215MKOAHCollars.csv?delimiter=%5B,%5D
>> &delimiterType=regexp&xField=East_LG&yField=North_LG is not a valid
>> layer and can not be added to the map
> I've noticed the same thing this afternoon, and was about to try to
> isolate the cause so as to file a bug report.
> I also updated GDAL and maybe some other things at the same time as QGIS
> - did you do the same, or did you only update QGIS?
>> I've reinstalled trunk (which reinstalled the plugin) to no effect.
>> Does anyone have any other suggestions.
> Thanks, at least I now know that is not the solution :)
I'm afraid that I also updated a bundle of things at once.
Given it's been a while since I updated, I suspect the installer would have got grumpy at me for not updating other things as well if I had tried to just update qgis.
- ramon.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110215/2df331bf/attachment.html>
