[Qgis-user] qgis/osgeo4w error after update
Jürgen E. Fischer jef at norbit.de
Wed Feb 16 11:40:11 PST 2011
Hi Anita,
On Wed, 16. Feb 2011 at 15:40:31 +0100, Anita Graser wrote:
> Running the installer shows and MD5 failure for msvcrt.
Um, sounds like a different problem.  Can you verify that your msvcrt package
file and setup.ini in your matches following data?
file					size		md5
release/msvcrt/msvcrt-1.0.1-5.tar.bz2	12821300	f0939edbba082627a51167f36984c3b9
setup.ini				64335		780083fbe0710a44c79854e6be8ef587
If there is a mismatch, there might be a proxy problem.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
