[Qgis-user] Send us your tips!
Pedro Venâncio pedrongvenancio at yahoo.com
Tue Feb 22 03:50:20 PST 2011
That's it! Excellent!
 This idea of the tips is very good!
Tanks!
Pedro
--- On Tue, 2/22/11, Andreas Neumann <a.neumann at carto.net> wrote:
Hi Pedro,
For scale you can place a scalebar and then select style "Numeric". The only issue I see is that you can't select a text-alignment. Currently, it is always left aligned. A future version should also support center and right aligned scalebars/scale values.
I know - it is a bit confusing that you have to select a scalebar for a numeric scale values - that's why we should probably also do a tip on that.
Tim - here is another tip:
Title: Numeric scale value in map layout linked to map frame
Content: If you want to place a text label as a placeholder for the current scale, linked to a map frame, you need to place a scalebar and set the style to 'Numeric'. You need to select the map frame, if there is more than one.
Andreas
On Tue, 22 Feb 2011 02:07:15 -0800 (PST), Pedro Venâncio wrote:
> Hello Andreas,
> This tip is great!
>  Is there any hint of its kind for the scale?
>  Thanks!
> Pedro Venancio
> --- On MON, 2/21/11, ANDREAS NEUMANN __ wrote:
>> Hi Tim
>> Where should people who are not developers send the tips to? To you?
>> Here is one contribution:
>> Title: Add the current date to a map layout
>> Content: You can add a current date variable to your map layout.
>> Create a regular text label and add the string
>> $CURRENT_DATE(yyyy-MM-dd) to the text box. See the
>> http://doc.qt.nokia.com/latest/qdate.html#toString
>> [1]">QDate::toString format documentation for the possible date
>> formats.
>> Andreas
> Links:
> [1] http://doc.qt.nokia.com/latest/qdate.html#toString
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110222/cd2b5975/attachment.html>
