[Qgis-user] Re:Newbie question - gml files
Noli Sicad nsicad at gmail.com
Sun Jan 2 15:48:10 PST 2011
Hi Sam,
I think you have to uninstall the previous installation of QGIS in Add
/ Remove or in Uninstall QGIS (I am not using Windows right now so I
don't exactly know). If not remove manually the QGIS directory and
install again.
QtCore4.dll is Qt library for Qt window toolkit which included in
QGIS. QGIS will not work without the dynamic library.
FWTools is not part of the QGIS, you don't probably need it if you
have work the org2org.exe program in gdal already.
Noli
On 1/3/11, Sam Vekemans <acrosscanadatrails at gmail.com> wrote:
> thanks
> will try 4326 instead .... and just remove that last program that
> doesnt help. :)
> cheers,
> sam
> On 1/2/11, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>>> it took some time to number crunch, but it did make a whole bunch of .shp
>>> files :) ... accept the projection is still off.
>>> So i need to add "EPSG : 4617"   or some random 4 digit number that will
>>> work.
>>> ogr2ogr.exe -f "ESRI Shapefile" -t_srs EPSG:4617 d:\try3-gdal NL_LX.gml
>>> What i dont know is exactly which projection code to use or the prefix to
>>> use for it. http://www.gdal.org/ogr2ogr.html assumes that the user
>>> already
>>> knows how to use the program :)
>>> ... if i get this right then there is no need to mess with qgis :-)
>> Try,
>> EPSG: 4326 for WGS84
>> http://nsidc.org/data/atlas/epsg_4326.html
>> This is the metafile of one of the file.
>> General:
>> Storage type of this layer: GML
>> Source for this layer:
>> /home/noli/Downloads/A_NZ/NL_EN/NL_EN.gml|layername=EN_1360049_0
>> Geometry type of the features in this layer: Point
>> The number of features in this layer: 3
>> Editing capabilities of this layer:
>> Extents:
>> In layer spatial reference system units : xMin,yMin 48.4084,-66.6146 :
>> xMax,yMax 54.472,-55.0224
>> Layer Spatial Reference System:
>> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
>> Noli
> Twitter: @Acrosscanada
> Blogs: http://acrosscanadatrails.posterous.com/
> http://Acrosscanadatrails.blogspot.com
> Facebook: http://www.facebook.com/sam.vekemans
> Skype: samvekemans
> IRC: irc://irc.oftc.net #osm-ca Canadian OSM channel (an open chat room)
> @Acrosscanadatrails
