[Qgis-user] Bugs
Nathan Woodrow madmanwoo at gmail.com
Thu Jul 7 06:15:44 PDT 2011
Hi Jonathan,
Regarding the raster, try opening a small one first and going the raster
properties (right click on layer->properties) and turn Contrast Enhancement
to No Stretch. Click the little save button and it will save option for
every raster.
See if that helps .
- Nathan
On Thu, Jul 7, 2011 at 10:54 PM, <jonathanmoules at warwickshire.gov.uk> wrote:
> Hi Guys,
>         A few bugs with QGIS 1.7.0. Unfortunately there's no obvious way to
> actually create an account or report bugs on your bug tracker so I'm forced
> to post them here.
> 1) I have a ~600MB raster in JP2000 format (*.jp2). QGIS doesn't seem to be
> able to load this, at least not in a timely manner. It spent at least 5 mins
> sitting there eating 100% CPU and using quite a bit of RAM.
> I also have a ~4GB ECW file which similar things happen with. Both files
> are projected (OSGB - 27700) and I'm fairly sure they have pyramids.
> MapInfo, ArcGIS, MapModeller (all proprietary), and MapWindow (Open Source)
> are all capable of displaying both images in fractions of a second.
> This is on a Windows 2008 R2 Machine.
> 2) I load a shapefile that's projected in British National Grid into QGIS.
> The built in QGIS scale shows "degrees" rather than "metres" as the
> measurement unit despite showing "0" to "30,000" numerically (so it is
> showing metres, it's just incorrectly saying "degrees". This is to a new map
> that has no other layers added.
> 3) Why is there a "(c) QGIS 2011" in the bottom right of the map viewer?
> 99% + of other programs use the Help->About page for that.
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110707/0e21d15d/attachment.html>
